Missing Text
Oswin Paul SSF
Since a recent update I can no longer see some of the text on the right hand side of the Connect Player display. I have tried to extend the RH side of the window but this makes no difference. I removed the program then inserted the original disc and everything was OK but when I download updates the display went again. The Top Bar is correct it is only the list of Albums etc that is not displaying properly.
