PaScal Posted April 17, 2007 Report Share Posted April 17, 2007 Hello,I was very happy with winamp pluging, but unfortunetly I formated my Sony NW-A1000 and now it doesn't works. That was my mistake and now, when I do all from FAQ it is the same problem. In media librery can I drag the file or send it to device, but nothing is visible in the list of walkman. There is only All (0 artists) and nothing more. When I try to use Sonicstage, It works, but I hate that program. It's very slow and unconfortable.Could You help me please? Quote Link to comment Share on other sites More sharing options...
otiasj Posted April 18, 2007 Report Share Posted April 18, 2007 (edited) Hello,1- You formatted from windows? or from the device?2- did you create a OMGAUDIO directory3- did you create a OMGAUDIO\4CNTINF.DAT file? (make sure it's not a 04CNTINF.DAT.txt file! )4- did you create a OMGAUDIO\nocode.txt file? (NW-A1000 is not protected)5- you can NOT drag and drop on the "X: Sony walkman" this is not supported you must use right click->sent to->x: Sony Walkman or try to create a m3u playlist drag it from windows explorer to the ml_sony window. Edited April 18, 2007 by otiasj Quote Link to comment Share on other sites More sharing options...
PaScal Posted April 22, 2007 Author Report Share Posted April 22, 2007 Hello,thank You for your replay Problem starts, when I formatted my player from Windows. Than I try to do all from FAQ. Initialize from player and do it again. But it is the same state. I can make the folder OMGAUDIO and create the files there, but when I connect the player and try to send files on it, it doesn't works All looks same as before, but the files in ML which were sends I can't see in playlist. There is only "All (0 artists)" :-(Do you think the new firmware will help's me? Thank YouBest regards Quote Link to comment Share on other sites More sharing options...
PaScal Posted April 22, 2007 Author Report Share Posted April 22, 2007 And the one thing. I can delete files from Winamp, which were transfer from SonicStage, but can't add. Quote Link to comment Share on other sites More sharing options...
PaScal Posted April 22, 2007 Author Report Share Posted April 22, 2007 I found the problem. It was in new version of Winamp (5.34 beta). Now I have 5.32 and it is OK :-) Quote Link to comment Share on other sites More sharing options...
imhambone Posted April 30, 2007 Report Share Posted April 30, 2007 otiasj said: Hello,1- You formatted from windows? or from the device?2- did you create a OMGAUDIO directory3- did you create a OMGAUDIO\4CNTINF.DAT file? (make sure it's not a 04CNTINF.DAT.txt file! )4- did you create a OMGAUDIO\nocode.txt file? (NW-A1000 is not protected)5- you can NOT drag and drop on the "X: Sony walkman" this is not supported you must use right click->sent to->x: Sony Walkman or try to create a m3u playlist drag it from windows explorer to the ml_sony window.Can you give me a link to the FAQ's. I am going to try and format my NW-A1000 and use it with Winamp. Quote Link to comment Share on other sites More sharing options...
otiasj Posted July 3, 2007 Report Share Posted July 3, 2007 the faq is here faq Quote Link to comment Share on other sites More sharing options...
javitenorio Posted July 19, 2007 Report Share Posted July 19, 2007 hi, I'm spanish.The first ... sorry for my english, it's very poor, hehehe.I hava got a Mp3 sony nw-a1000 and I have got a seriously problem with it.I use the opciotn HD from the mp3 (device) and now it is empty, there arent files in it. I can use connect player now because I need the files and the folder that there was in the device.Can you tell me a link to get that files and folders?Thank you very muchJavi. Quote Link to comment Share on other sites More sharing options...
otiasj Posted July 20, 2007 Report Share Posted July 20, 2007 Hello Javi,Sorry I did not quite understand your problem,You have formatted your device? (what is opciotn HD?)and want to recreate the database file?if you did, you just have to plug your device in any software, sonicstage, connect player or ml_sony. transfert some songs, and you should be ok...see ya Quote Link to comment Share on other sites More sharing options...
