Problems SS 4.3 and with previous versions
chris72
hello! and sorry for my english..
I've a problem with SonicStage..
I've Windows 2000 (SP4) and ASUS DRW-1608 CD/DVD burner.
Using SonicStage 4.3, the option TRANSFER didnt display any device to select.. I cant transfer any file because there is not any option.
and when I install SonicStage 3.x / 4.0 / 4.1 / 4.2, the Transfer option displays correctly (I use Create an Atrac CD), but when I try to transfer the files from my library to the Atrac CD panel, I receive the following message:
Cannot create a CD because of copyright restrictions.
(the first theme here)
Cannot transfer the track because the rights for transferring to an ATRAC CD have been expended.
(You can confirm the remaining ATRAC CD transfer count in the track properties.)
(the rest of the themes selected are listed here)
I used SonicStage 4.3 in the past, but I changed my CD/DVD burner and my motherboard, and now is impossible to me to use it again.
I will thanks a lot any help to solve this.
Thanks
Christian
