Sonicstage cannot display itself properly
Niobium
Hi there, I've just bought an NW-A808 and am having serious problems getting Sonicstage 4.3 (or 4, I tried that as well) to work. I can install it fine, and can see the player, but the menu bar constantly flickers and I can't actually click anything. The only way I can get drop down menus to appear, select tracks, move the scroll bar or bring up right click menus is to switch to another window then back again, which causes the menu to pop up over whatever is running or the scroll bar to jump when I go back to SS. This makes it impossible to select more than about 3 tracks at a time, I've tried to take screenshots but they don't show the flickering, here's what it looks like when I right click a track then switch to another window:
http://paintedover.com/uploads/show.php?lo...untitled_12.jpg
I've tried reinstalling 4.3, installing 4.0 and nothing seems to make any difference, does anyone know what could be causing this?
Edit: Just discovered that I can select tracks if I click them then hit Ctrl, likewise I can slowly select multiple tracks/albums if I keep Ctrl held down, I still can't access any menus though.
Edit 2: Hitting any key after clicking seems to "update" the display, so if I click the scroll bar then hit a key it will jump to where I clicked it.
Edited by Niobium
