need help in transfering song using ss 4.3
yujin86
i am using ss4.3 but ater tat downgrade to 4.1 due to too many songs in chinese and jap word. but now i got a big big prob. i notice tat once i turn on my bluetooth on my laptop and ss 4.1 will crash and cant load any song into mp s705. but it is perfectly for listening music and other func. in ss4.1 . i hav to reinstall 4.1 to fix tis prob.......... any solution to tis???
de second prob is i was frustratred wif 4.1 so i dl 4.3 and install it. but i notice tat i can transfer song from my c drive which is where my vista system located, and d drive as well. but the song transfer from d drive cant convert to any other format b4 transfering only de songs from c drive can convert? why does it so? but previously my 4.3 work perfectly?
i notice tat everytime i install my ss sure gt sumthing cant use de....... really sad wif ss.............
Q1. I am using Traditinal Chinese Windows + TC SS4.3, and so far no problem on transfering Japanese title + Chinese (Traditional , or Simplified (some characters are garbled with ?)) title + English tile songs at one time. My current devices are NW-A3000, VAIO VGF-AP1, and Aiwa XDM-S700. It seems SS4.3 can handle it provided your default Windows OS language is TC or SC (or changing it from English OS thru Control Panel, or Multi-Language Interface)
As mentioned, you 're using bluetooth. I believe you're using bluetooth (USB) mobile earphone as Windows system sound output while transfering (with listening enabled) to Sony device. Try turning off the sound, or get latest driver on that product.
Q2. Your problem may be SS supported format issue, (not a file sytem issue), or your original files registered on old database moved and the SS has not been updated with its location.
