cool_rock Posted July 28, 2007 Report Share Posted July 28, 2007 well i want to ask that does the headphone gold platting wear with respect to time and does it effect the sq.bcoz i have mine for around 5 months and i have noticed that my gold platting of the headphones had started to fade withrespect to use is it normal or i clean the headphones plug with softcotton cloth occasionaly does it fade the gold platting. Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted July 29, 2007 Report Share Posted July 29, 2007 I'm not sure, whether removal of gold plating effects the sound quality or not (If it does,then it must be very little, which we cannot make out ).Even gold plating of many of my earphones plugs have removed due to normal wear and tear . Quote Link to comment Share on other sites More sharing options...
cool_rock Posted July 29, 2007 Author Report Share Posted July 29, 2007 well thanks for u reply well i want to ask that does the new walkman headphones of high quality also their gold plating vanishes with respect to time or is it more heavily coated than previous ones Quote Link to comment Share on other sites More sharing options...
Guest Stuge Posted July 30, 2007 Report Share Posted July 30, 2007 well thanks for u reply well i want to ask that does the new walkman headphones of high quality also their gold plating vanishes with respect to time or is it more heavily coated than previous onesFrom my experiance coating is still of same thickness . Quote Link to comment Share on other sites More sharing options...
