Just a tip
Trondis
Hi!
If you go to ebay (www.ebay.com) and search for "etymotic tips sony", you will get several offerings for Etymotic earphones tips adapted for Sony earphones. I was tempted by this offering and bought a pair. It is the Etymotic triple flange tips that are used. Maybe it's luxury, since the earphones already were quite good. I have Sony MDR-NC22. But I am very pleased with these new tips. It makes the phones fit better in the ears. They don't fall out as easily, or as I have experienced, leave the tip in the ear when I pull out the phones. And it seams like the sound is better also. I think it is because the phones are more stable inside the ear and better directed at the eardrum. And they give better isolation against external sounds also.
Another option I have seen recommended is to use the foam tips for Shure E2. They supposedly fit also (other Shure tips doesn't). I haven't been able to try these, but this kind of tips supposedly isolate even better that the Etymotic triple flange tips.
