Azureal Posted September 5, 2007 Report Share Posted September 5, 2007 (edited) I have the Connect Player v4.3 installed on a Windows XP Pro machine. I have used this machine to manage my ATRAC3/plus library of about 20GB for at least one year. I regularly use the CP interface on the PC to play music while I work. Recently, I downloaded some music from the Connect store and wanted to update my HD5 player with the new titles.When I connect the HD5 unit to the PC, CP v4.3 recognizes it, however when I try to access it CP crashes with the error "Omgjbox.exe has encountered a problem and needs to close.".I have connected another device, my MZ-NH1 and I am able to read disks and manipulate music on it without incident, this is not the case with the HD5.I performed an "Initialize HDD" and a restoration to "Factory Settings" from within the "Options --> Initialize System" selection on the HD5 menu. After performing this on one occasion, I was prompted to re-authorize the device, which I did via Connect and then it appeared as if I was going to be able to copy music to the device. I selected a bunch of albums and clicked transfer. The transfer began but CP v4.3 crashed again. This time it left the unit in a state where upon disconnection from the PC, it had an error on the screen about a corrupted database. No music is on the device now at all.I have a second HD5 which belongs to my wife which exhibits the same problem.I downloaded the CP v4.3 installer but it will not install over the existing installation, it seems I will need to uninstall CP and reinstall it to get a clean installation. How will this affect my library of music?Does anyone have any suggestions on what course of action to take?tia,Azureal Edited September 5, 2007 by Azureal Quote Link to comment Share on other sites More sharing options...
Azureal Posted September 6, 2007 Author Report Share Posted September 6, 2007 After several attempts at uninstalling and reinstalling CP v4.3, I finally ran across a few posts about issues with this version and backed down to v4.2. Everything is working as expected now. I am able to manage and manipulate music on both HD5 units. Quote Link to comment Share on other sites More sharing options...
