justeoin Posted November 12, 2007 Report Share Posted November 12, 2007 Hi, i got a Nw-a3000 a while back, and used connect player (lol) and when that refused to work i stopped using my mp3 player for a good few months. . now, i really want to start using it and find out that Sonicstage is the software to use. . so i have the 4.3 version, and i put music into my library easily. . as you would expect - even from a monkey with brain damage. So, i plug in my player and nothing happens. my computer picks up that something is there - but sonicstage doesn't. so. . im sitting there with all my music ready to transfer . .but to where?has anyone else had similar problems or know anything i could do to sort this out?Thanks!Eoin. Quote Link to comment Share on other sites More sharing options...
Avrin Posted November 13, 2007 Report Share Posted November 13, 2007 May be you have a VAIO version of SonicStage 4.3, which doesn't include any drivers. You may try downloading drivers from here: http://dl1.aii.co.jp/contents/connect/_dat...r/pa_driver.zip . Exit SonicStage, disconnect the player, unzip the archive, run setup, and, when it is finished, restart your computer (even if it doesn't ask you to). After the computer has restarted, reconnect the player and run Sonic Stage. In any case things will not get any worse, since these drivers are exactly what the web-installer of SonicStage 4.3 downloads. Quote Link to comment Share on other sites More sharing options...
