Sonicstage 4.3 Backup Tool Problem
fozzman71
As the backuptool starts to calculate the disk space required for the backup I get
"Omgbkup.exe has encountered a problem and needs to close. We are sorry for the inconvenience."
Event viewer reveals
Faulting application omgbkup.exe, version 4.3.1.14020, faulting module msvcr71.dll, version 7.10.3052.4, fault address 0x00010440.
I've tried re-installing SS 4.3 and msvcr71.dll.
As I've been using Omgbkup for the last 3-yrs with no problem I'm assuming my PC has somehow been corrupted.
I'll be grateful for any thoughts.........
The first question that comes to mind is: What version of Windows are you using?
If you are using XP, it may be worth trying to install an earlier version of SonicStage (version 4.0 is available as a full download from this site, version 4.2 may also be available elsewhere).
Otherwise it may well be an issue with your PC - SS does seem to be very fussy about the PC it is on.
