Trying to restore Backupped Library
trashben-NW-A3000
  trashben-NW-A3000 said:
Hi everyone, I installed a new Window Vista on my PC and tried to restore previously backup library
Previously SonicStage 4.3 onto Win Xp Sp2: Backup into hardisk directory and all ok
Restoring, when accessing internet return error 0x307
Any help ?
Hi there, first of all - how/where did you back up the library? Secondly, when you installed Vista, did you also install a fresh copy of SonicStage, or did you use the one that was still on your PC?
For any hope of a successful back up when changing PCs, you have to 1) Back up the library to removable media or an external hard drive, and 2) Install Sonicstage on the new computer. Finally, once SS has been re-installed, use the backup tool to restore your library from wherever it's been backed up to.
I'm not sure, but I think the error message you got might relate to the fact that your library wasn't authenticated during the restore process.
Hi, thank you for your reply.
First of all I backupped the library on a different partition on another disk of my set / pc.
I installed a fresh copy of SS 4.3 in Vista and then recalled the backup tool to restore the library
After the four first steps the tool tried to connect with "I don't know" to authenticate the library.
First tries all concluded with the connection error I posted.
After some other tries the tool stayed connected (at least I could only see the window opened, but nothing I can say about it's working or not) for at least 4-5 hours and then
I stopped by closing the task.
my database is 7 Gb and over, so I didn't know if the tool had to pass all over to authenticate.
However today I had to say some connections didn't work well (Microdoft site wasn't reachble all over the day.
So I'll give another try in the future days.
Can you tell me something about the duration of the authentication time?
Is it depending on the amount of Gb of the Db?
To which site do the connection attach?
So I'll be back in a few days to report some news
Thank You for all, and at last I can say I have no other chanche than using an internal device to do the backup, cause only DVD DL (and it seems to me I read Backup Tool cannot use DVD DL) can hold my entire db.
  • 9 years later...
