Help with Nw-s705f displaying Chinese
Dm22
I have read this => http://www.atraclife.com/forums/index.php?showtopic=4
I have to use AppLocale to load Sonic Stage for it to display chinese
but my computer locale is already in Chinese (PRC) and if i use AppLocale, i'll have to change to english first (restarting comp)
and change back afterwards...
anyone know a good way around this?
I'm using a Nw-s705f
Here is my experience, I have done the following and so far the Trad/Simp Chinese, and Japanese characters are displayed correctly in my SS4.2/4.3. Use default language SS is OK.
Simply install the "Minimum Installation (you can uncheck the Japanese input method for further)" of "Unicode for Chinese and Japanese (Unicode Extension) for Windows (Windows 95 98 ME 2000 XP) http://search.cpatch.org/download/patchuti...odeaton_250.exe (Non-Microsoft software). It works for English, Simplified/Tradtional Chinese Windows, and/or Jap. Windows (not tested so far on mine). Yeah, FreeBSD and Linux are supported (get it from Homepage). There is no mention for Windows Vista. The installation interface will be changed according to your default language. The only discrepancy is it will mess up the "FrontPage XP" code, and warning will be displayed if there. There is no need to edit registry entry!
1. No need to change as following(depends on your Windows original default):
Regional and Language Options>Text Services and Input Languages>Default input language>English (United States) - US
2. No need to run with AppLocale (both mentioned programs), forget it.
If Japanese/Chinese characters are still garbled, change the default language (normally there is no need to do this step), say, to Chinese as following:
Regional and Language Options>Advanced>Language for non-Unicode programs>Chinese ...
It works for latest and earlier SS versions on Windows 2000 or Windows XP. Not tested on Vista.
HomePage in Traditional Chinese only http://uao.cpatch.org/index.php?%E9%A6%96%E9%A0%81
Edited by Heman
