hander Posted February 7, 2008 Report Share Posted February 7, 2008 I've installed WinAmp + ML_Sony and it's working fine.. But all playlists created in winamp and applied to NW-S205F doesn't work when i select the option playlist on the player.. How do i fix it? Thanks! Quote Link to comment Share on other sites More sharing options...
eric.strife Posted March 13, 2008 Report Share Posted March 13, 2008 hander, I have the NW-S203F, just installed ml_sony today and have come across the same problem.When i make them in winamp, everything seems fine, then when i try to select playlists, it says "NO ITEM"hopefully it can be fixed... though even if playlists dont specifically work with our series of player, its a shiteload better than sonicstage. ; Quote Link to comment Share on other sites More sharing options...
eric.strife Posted March 23, 2008 Report Share Posted March 23, 2008 so no one on this forum has any ideas for us?:'(i miss playlists... i might have to retreat to sonicstage... Quote Link to comment Share on other sites More sharing options...
guy4even Posted July 17, 2008 Report Share Posted July 17, 2008 I had just come across this beautiful plugin which has taken out all of my struggles with sonicstage. The authorisation and deauthorisation are very cumbersome and beginning from the next year, the connect store servers will be removed and no further authorisations and deauthorisations are possible. So this has led me to search for alternatives to sonicstage and i found this wonderful plugin. I loved this plugin but the only problem i have is with playlists. When i create the playlist using winamp and ml-sony, my player (sorry i forgot to tell you that it is a NW-E005F) shows no items in the playlist. I really love playlists and would like to have them on my player. I had searched for this problem over the forum, but unfortunately there is no solution and it still is reported as a bug. I am wishing it would be corrected soon.. Quote Link to comment Share on other sites More sharing options...
