NWZ-s618F test mode
Dharmesh
Hi,
Is there anyway in unlocking the full volume potential of the NWZ-S618F walkman, because when the volume is on 20, it barely increases untill 30. Also I have found the test mode file for the NWZ-A82XX series (bluetooth walkmans) and this testmode work's on the NWZ-S618F walkman.
But there must be a way to make the NWZ-S618F to Japanese spec as this is much louder than the UK spec, as a friend of mine has the Japanese version.
The testmode pdf can be downloaded from -
http://rapidshare.com/files/117596728/NWZ-A826.pdf
This link works. Also, look at the following attachment
Please advise as there must be way to make the volume louder.
2 answers to this question
Hi.
you have solved a problem for me.
I have been trying to get into test mode for my NWZ-A818, I have followed the instuction in the service manual, but it does not work.
I noticed the picture you posted had a different sequence of keys to get into test mode, and it worked.
The manual that did not work for me is NW-A805.pdf it mentions the NWZ-A818 on ever page.
Your NWZ-A826.pdf manual works, and it`s not even for my NWZ-A818 completely different pictures.
I wonder how many other people have had this problem.
thanks
Edited by Tinderbox (UK)
