guy1005 Posted September 5, 2008 Report Share Posted September 5, 2008 When I connect my NW-A828 with my laptop (using Vista Home premium) by sonicstage 4.3 it says “the connection between the device and the computer is unstable…”. Who can help me now?? Thanks alot. Quote Link to comment Share on other sites More sharing options...
0 juli_ Posted September 5, 2008 Report Share Posted September 5, 2008 When I connect my NW-A828 with my laptop (using Vista Home premium) by sonicstage 4.3 it says "the connection between the device and the computer is unstable…". Who can help me now?? Thanks alot.If you're using the non-Japanese version, then it doesn't use SonicStage/Atrac anymore.You need to use Windows Media Player or Windows Explorer to drag and drop the music on your A828.Or you can use Media Manager, which should be on your software disc.Hope that helps. Quote Link to comment Share on other sites More sharing options...
guy1005
1 answer to this question
