suggestions to sync from itunes playlist to a818?
rtsai
I just got a a818 and i switch from an old ipod nano. My playlists are still in itunes and I would like use those to sync to my a818. I used this to change the xml itunes exported playlist to m3u8 then imported to media monkey. However, some, but not all of the asian characters show up. I think some of them most not be in the correct unicode format or something. I am running vista 64bit in English if that makes a difference. Same issue with wmp11. Winamp reads the m3u8 perfecly, but I can't sync it with winamp. Any suggestions on what I can do? Thanks for the input.
