Is it possible to record using microphone with MZ-505?
Guest Anonymous
Guest Anonymous
Hi,
I have a MZ-505, and although it does not have a mic input, is it possible to do live recordings? Since it can record from powered sources such as stereos, is there a simple circuit that I can construct using a regular unpowered mic, or a special mic that I should use?
Thanks,
-Dan
If you're competent with electronics, you can of course rig yourself an amplifier and use the n505's line in. For the more electrically inept (such as myself) the easiest option would be to buy a battery box or mic pre-amp. These can be obtained from soundprofessionals.com, amongst others. Or get the N707...
