Minidisc jamming problem on live recording
Guest Anonymous
Guest Anonymous
Hello,
I have a problem. I made a recording of Coldplay live at Plymouth ( a
homecoming gig) and had a problem with my MD. It was a Sharp MT877 MD
recorder. There is a problem with the laser. Or rather there was. It has now
been fixed. It did not write a table of contents. I managed to recover the
disk by copying the table of contents from one disc to another. I have used
this procedure before and it worked successfully. However this time the disk
is fragmented and does not play properly. It playes for a second or so and
then jams for 10 seconds. The only method I can think of to recover the
audio is to record it to pc as a wav file and then manually edit out the
silence using Cool Edit Pro. This would take an eternity and there is no
guarantee that my edits will be flush. So what I really want is a way of
ripping the audio to a pc file so that I can then burn it to CD. Does anyone
have a method or the equipment to help me do this? The recording is in Long
Play (LP). Any advice someone can give me would be greatly appreciated. This
is a very important recording as they had some of my friends guest on stage.
Regards
Peter Bullock
pete.bullock@virgin.net
