mz-n505 song fragmentation
Guest Anonymous
Guest Anonymous
Sometimes, after heavy listening to a single md, and hitting ff/rr quite a few times, a song or two will start to fragment in seperate pieces. This does not create a gap between the tracks, so as long as I play straight through everything is fine, but rr/fw can start to get real annoying unless I rip the songs from the cd again.
Is there any fix for this? Has anyone ever heard of this before? Reripping isn't a big deal, but it would be nice if I could avoid it.
Guest Anonymous
(It's still me)
I think the problem is caused by the ff button, which is leaving a trackmarker rather than simply skipping to the next song. If I get a remote I think the issue will be solved. (I've used one before on this unit and hadn't noticed fragmentation occuring.)
