Uploading
Guest Anonymous
Guest Anonymous
Is there some way you can upload the music from live recordings or say... a recording from the radio onto the computer? Do you need to buy some kind of special device in order to do it? Or if you can't do this...is it possible to connect the MDunit to a cd-burner and burn it on a CD?
You can 'upload' onto a PC or CD burner, but only in real time. In effect you are making a recording of your recording. You don't need any special equipment, just an appropriate analog cable connected to a line in, and recording software for a PC. If you have a deck with digital out you can record digitally (better quality) on a CD recorder or PC with digital in.
