combo mic preamp/battery module w/bass rolloff...in Canada?
SimonMagus
Hey there,
For some time I have been shopping for a combination mic preamp/battery module with bass rolloff that will cover all recording situations, as I will be taking my Sharp MT880 and SoundPros in-ear binaurals backpacking in various parts of the world for a couple of years to record ambient sounds. So far I have found the SoundPros' SP-SPSB-1, which is the "stealthiest" for my uses. there are, however, problems:
1) With all the required mods this will cost about $400CDN; but more importantly,
2) Since SoundPros are irritatingly (and, IMHO, prohibitively) ethical about international shipping, I stand to get shafted on punitive Canadian duty fees since I'm ordering from the US.
Can anyone recommend a good place in Canada that might have what I need (or other places in the US)? Thanks.
Guest Anonymous
Well we(www.stealthaudio.net) are located in canada. How ever we dont sell pre-amps. We are able to do many custom options such as multiple bass roll off settings(all selected by you) ours can actually made accessable outside the box without opening it. We also will charge alot less than sound pros.
There is also an archos distributer in canada that sells a small pre-amp for 49$.
if you have any quesions let me know.
Thanks
Scott
stealth_audio@canada.com
