Microphones probably a daft question
Guest Anonymous
Guest Anonymous
Being new to minidisc, can anybody explain the difference between minidisc microphones and just using a normal type of microphone.
What I want to do is record lectures. If you cannot do this using a normal microphone can anyone recommend a reasonable priced one
thanks
pretty much the same. a mic that is 'designed' for minidisc will require lower power to operate, which is suited for the weak preamp of the MD, but most cosumer-grade mics should work.
for recording lectures, just get the cheapest mic you can find at your local electronics store.
