triggerhippie Posted February 4, 2003 Report Share Posted February 4, 2003 Hi all, I am in the market for a portable minidisc recorder. I have never bought anything with MD on it before so was wondering if the experts here could suggest something. It absolutely must have a radio though. Ideally it must have compression facility. And finally, my budget is under £200 although if there is a cracking good recorder over my budget then I may still consider it I look forward to all your suggestions. Greg :? Quote Link to comment Share on other sites More sharing options...
Takman Posted February 4, 2003 Report Share Posted February 4, 2003 You want a radio tuner with your portable MD recorder? The G755 is your only option. Should be within your budget, £170 or so, I think. Quote Link to comment Share on other sites More sharing options...
triggerhippie Posted February 5, 2003 Author Report Share Posted February 5, 2003 Thanks for the suggestion. It sounds a bit weird but I'm going to answer my own query as I just got this email from avland : "This should satisfy your requirements: It should be out next month and can be now pre-ordered at £199.95> http://av-land.co.uk/sony/mznf810/index.htm" Hope that helps anyone else who is looking for the same. Quote Link to comment Share on other sites More sharing options...
