Hooking up Minidisc player to existing seperates?
Samba
Might sound like a basic question but I am looking to buy a Minidisc player to add to my seperates, my amp is a Marantz PM66SE, it doesn't have an optical input so I assume I obviously need to look for one with coaxial. Also where do I hook it up to in the back of the amp, the Aux? And is it the same when I want to listen to it, do I need to select Aux on the amp? Any advice would be appreciated.
Are you looking for a minisc deck or portable player/recorder?
If it's a deck you just need to connect its line out to a spare line in (not phono) on your amp. You get suitable (cheap) RCA cables with the deck.
If you want a portable MD unit you'll need an RCA to minijack plug connected to the MD's headphone jack.
Yes, the aux input will do, any of the inputs would be fine except phono. Then select Aux on your amp to play through your speakers.
If you have a spare tape loop on your amp (it should say Tape1 or Tape 2 on the back with separate IN and OUT plugs), you might find that useful for recording to MD as well as playing. You'd need 2 RCA cables in that case.
