Guest Anonymous Posted February 7, 2003 Report Share Posted February 7, 2003 Hello, Ive had my mz-r500 for almost 2 years and it has been great. Awhile back it wouldnt read discs(said nodisc) but they after a little while it read the cleaining disc and all was well. BUT now the problem has arisen once again... its been more than a week and it still wont read the cleaning disc or anything else.... I called the place i bought it from(bestbuy) and they basically they couldnt do anything and sony well... ya nothing... So im stuck... Am i screwed or wut? Thanks cOrY Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 11, 2003 Report Share Posted February 11, 2003 anyone??? Quote Link to comment Share on other sites More sharing options...
me Posted February 11, 2003 Report Share Posted February 11, 2003 obtain some isopropyl alcohol - 91% or higher in concentration. Take a q-tip (that's a cotton bud, right?), dip it in the alcohol, apply it to the lens (clear thing in the middle of the MD, to the right of the motor spindle). Only put a very small drop on (like... moisten the q-tip, don't get a giant visible drop on it). If that doesn't help, send it to sony for repair. Quote Link to comment Share on other sites More sharing options...
David Popovits_ Posted February 11, 2003 Report Share Posted February 11, 2003 Please do not use alcohol, as some MD lens are plastic made (not glass) and you may make thinks worse. After cleanning try to readjust in test mode. If it wouldn't help go to a good repair shop or buy yourself a new MD David Popovits Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 11, 2003 Report Share Posted February 11, 2003 so i shouldnt use alchohol??? i dont know what test mode is... thanks Quote Link to comment Share on other sites More sharing options...
me Posted February 12, 2003 Report Share Posted February 12, 2003 Can you verify this repair FAQ? http://www.repairfaq.org/REPAIR/F_cdfaq.html Quote Link to comment Share on other sites More sharing options...
