booyakafunk Posted February 8, 2003 Report Share Posted February 8, 2003 LINE IN recording - Help i've been bought a MT180 SHARP for Christmas and i want to use it for recording my Reggae stuff and to record African Drum...Can any of you cyber wizards help, i don't know what mic to use or if i need a pre amp for the Mic first. I'm in the Uk. I've seen that expensive Sony Mic for £90 but can i get cheaper, and if i can't would the Sony work on line in only.....Respect to any cyber wizard helpers etc. LEE xxxx Quote Link to comment Share on other sites More sharing options...
Mystyler Posted February 12, 2003 Report Share Posted February 12, 2003 Was bold really needed? We ain't blind... Anyway, you'll need a preamp to get the mic signal up to line levels, and then a battery box to power your mic. Quote Link to comment Share on other sites More sharing options...
SimonMagus Posted February 14, 2003 Report Share Posted February 14, 2003 Quote Was bold really needed? We ain't blind... Anyway, you'll need a preamp to get the mic signal up to line levels, and then a battery box to power your mic.Really, mystyler? I was under the impression that preamps were only really needed for recording quiet sounds, and that the battery module (with or without bass rolloff) is all you need for loud events? Quote Link to comment Share on other sites More sharing options...
Mystyler Posted February 15, 2003 Report Share Posted February 15, 2003 I'm only going with what I've been told. If I am wrong please correct me. It makes sense though - I've tried recording with a battery powered mic via line in, and got really quite results, even from loud sources. The battery module, (again, AFAIK) is only there to power the mic and increase sensitivity. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 24, 2003 Report Share Posted February 24, 2003 mmmm you are confusing things. If a mic needs a batery or phantom power is cause its a condenser mic, so it need to feed the condensor to work. Anyway line levels and mic levels are very different. The line levels are 1,22v and the mic may vary from 20-60mv (mini volts) thats way u need a preamp to get the right levels. I dont know what sony mic u talk about but a shure SM57 would be fine for drum sounds (there are betters of course but at really higher prices). And u can get a cheap mixer, may be a behringer (i know someones hate them, may be PROFESSIONAL musicians, but u cant get a better thing for that price, check the new UB models). They have small 2mic in mixers with line out for about 50 (u$s) Quote Link to comment Share on other sites More sharing options...
