ralphwiens Posted February 9, 2003 Report Share Posted February 9, 2003 I need a mini disk, simple to operate, to be able to download songs from the computer or cd player. I will do no live recordings, and I plan to listen to the music on a motorcycle so fidelity is not important. I had a MZ-N1 until recently (it was stolen) it met my needs but I thought hard to operate (confusing to me). It may still be the best choice, but need imput before I buy again. Ralph Quote Link to comment Share on other sites More sharing options...
Jermz Posted February 9, 2003 Report Share Posted February 9, 2003 MZ-N505 or one of the newer Type-S models when they come out. OR if you want something rugged go with the MZ-S1 S2 sports MD! I don't think we will see another sport MD for quite some time. Quote Link to comment Share on other sites More sharing options...
Mystyler Posted February 12, 2003 Report Share Posted February 12, 2003 Something easy to operate? Sharp IM-MT899. (Or MT880, depending where you live). NetMD, Sharp NetMD flagship and SIMPLE to use, esp compared to Sonys. However, the N505 or S1 are probably better suited to your needs - no mic input, cheaper, and dount quite sound up to the Sharps. Only downside is that due to smaller screens they can be even harder to use, and if you are in the USA the N505 don't come with a remote, and the S1 has no remote jack, so you are stuffed there. Maybe the N707 deserves a look. Quote Link to comment Share on other sites More sharing options...
