Audigy2->MZ-R90 & Denon DN-M2300R Problems
Guest Anonymous
Guest Anonymous
Hope someone can help me with a problem I am having recording via SB-Audigy 2 optically to a MZ-R90 and SPDIF to a Denon DN-M2300R.
The optically connected MZ is receiving a signal and starts to record (sound through Headphones) level moving and time ticking, however, once finished and TOC is written the track shows but can not play, if the disc is removed and inserted again BLANKDISC shows (no track). What gives?
Secondly the DN-M2300R connected via SPDIF receives no signal at all but can play into SPDIF on the Audigy 2. The Denon samples at 44.1 and is SPDIF and IEC-958 Type II compatible, the Audigy outputs at 48 or 96kHz is this a problem? As for the MZ I have no idea what it samples at. Tried connecting the Denon dig out to its in and a signal is received. What gives?
BTW before this sound card, burning discs and optically transferring to MZ worked fine.
Any help much appreciated.
Aloha
MT
