is the Sony S1 any good?
karatekid182
i wanna buy this MD player 4 a few reason:1) looks more durable compareted to the other one and i dont want it 2 break if i drop it by accident.2) it has a backlit LCD3)dont care it doesnt have a recording, or no mic input. Also i have a p2 400mgz with 320 mb of ram, how long would it take to convert my mp3 to the proper format for the mini disc? is the sound quality really that bad when its at Lp4?
You also know that it doesn't have a remote input?
It's not a bad recorder by any means. It is designed to be knocked around a bit, and hence why it is heavier and larger than other units. It seems fine for your needs.
It depends on several things, concerning LP4. If you use the supplied earbuds, then I seriously doubt you'll notice any difference at all. If you are using decent headphones, then you will notice that it is a bit below par, but comparable to 96kbps and 128kbps MP3s. Mainly people use it for voice recording, but some use digital CD dubs in LP4 for a disc to listen to on the move, where quality isn't important.
