Can't connect
RCartledge
Thanks to Mystyler and the other peolpe for helping me with learning how to record things onto MD. Now i have anotherp problem.
At the mo i use my playstation 2's digital out socket to record onto MD's but after recording 5 disks i now get an error saying Can't Connect when i try making a new recording. I've checked and double checked my connections and made sure that every thing is firmly plugged into the sockets but still get the error Can't Connect. it works when i use the leads that have the Red and White plugs on them but the only problem with that is that it doesn't seperate the tracks. Anyway, any ideas on how to fix the digital problem????
The digital cable isn't tightly kinked? Sharp twists can kill the signal.
Also, it could be a problem with your PS2 and CD. Some CDs refuse to be recorded from the PS2. This just occurs on a (or a select few) CD(s)?
