kelvinblade Posted February 25, 2003 Report Share Posted February 25, 2003 i am looking to buy a netmd. i was going to buy the 707 but i decided to look online for more options. i didn't know other brands like sharp make players like that too. i am mostly going to use it in the car and at work and i won't be doing a lot of live recording. could you guys recommend me a good player? nice looking, easy to use, long battery life. are new models going to come out soon so should i wait? thanks. i'm exploring more options such as sharp, panasonic, nec, and aiwa. but i don't know which models are netmd. could u guys tell me , thanks i advance. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 25, 2003 Report Share Posted February 25, 2003 Hi Kelvin, I am pretty much into the same use as you as far as using the MD. I use it for playing songs in my car, maybe a little audio recording in the future. I haf been researching mp3 players for a while and I eventually bought the Sony NET MD MZ-707. I haf been using it for about 2 days now. Currently, I only tested it by downloading mp3 songs using REALONE software. It worked great. The songs were clear, strong bass in the background. I am luving it. I use the remote to find my song that I want to play. I haf currently, 34 songs in one MD cassette. I am planning to get the LCD remote with backlit later on because one problem with the remote without LCD is you don't know if the player is on (the MD player is in the pouch all the time and I don't look at it often, don't need to). I don't know how u mean by easy to use. I can handle complicated stuff, and I do research ahead of time before I buy anything. If you need help, post something here, I will try to get back to u A.S.A.P. I hope this helps. Later dude Ryu 8) Quote Link to comment Share on other sites More sharing options...
