sharp mic level balance
Guest Anonymous
Guest Anonymous
Hi
I just bought a Sharp MT877, I've got it cheap, because it's an old
model, and I use it mainly for recording practice sessions with my band.
I've noticed that theres a little different in the level between the
right and left channel (about 1,5 db or so using Cubase level meters).
I tested the mic input with a mono line signal, and the difference were
still there, so it can't be the mics. The balance is perfect with the
line/optical input.
Is this acceptable ?-Or should I bring the MD back to the shop.
The recordings are in a very good quality, the stereo image just has a
little to much "left". I must admit I first got aware of the problem
when I saw the levels on my computer.
Is this a common problem with MDs ?
Thanks
Finn (Denmark)
