Best MD for price range?
Guest Anonymous
It really depends on how you will use the MD unit. Live recording? Playing your CD collections? Playing mp3 from your computer? If you can live without netmd, Sharp MT770 will be a great unit that will be worth every penny (it's about $220).
The only major difference is that n707 has a mic input and n505 doesn't. Sony's mic input has pretty bad reputation. Spending the price difference on a decent mic with preamp and use the line-in jack is a better way to go.
I heard the internals of these two models are almost exactly the same. n707 costs much more just for marketing purposes. So I think n505 is still the best deal.
Guest Anonymous
Ok, looks like Ill go with the 505, but I dont really like the gold color. You know any where that sells the 505S (silver) for around that same price?
Again, thanks a ton
ecost.com has it for $120 including shipping. You can probably find a new one at ebay for around $110 shipped.
I didn't like gold either. But I only use it for recording so I went for the price.
oh by the way, I strongly recommend sonicstage over openmg or realone. Once you tried all of them you will know what I mean.
