Guest Anonymous Posted March 1, 2003 Report Share Posted March 1, 2003 Hey, I have a MZ-N505 and I heard that I need a Battery Box to record live concerts beause the 505 dosen't have a mic input. My question, and its probably a very stupid one, is a battery box a battery module? Also does anyone know where I can get a good one? thanks in advance Quote Link to comment Share on other sites More sharing options...
Mulio! Posted March 2, 2003 Report Share Posted March 2, 2003 Yes, a battery box and a battery module are the same thing. You can buy one at www.soundprofessionals.com . Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 6, 2003 Report Share Posted March 6, 2003 you can also get them at www.stealthaudio.net www.microphonemadness.com or www.reactivesounds.com Quote Link to comment Share on other sites More sharing options...
highlandsun Posted March 8, 2003 Report Share Posted March 8, 2003 Be careful, make sure you get a battery module that includes a mic preamp. The basic units that Sound Professionals sells don't include the preamp, you have to get that as an additional option. If your recorder only has line-level inputs, then you need the preamp, not just a plain old battery box. Quote Link to comment Share on other sites More sharing options...
SimonMagus Posted March 10, 2003 Report Share Posted March 10, 2003 Be careful, make sure you get a battery module that includes a mic preamp. The basic units that Sound Professionals sells don't include the preamp, you have to get that as an additional option. If your recorder only has line-level inputs, then you need the preamp, not just a plain old battery box.As far as I've been told, though, you only need a mic preamp if you're recording really quiet, really distant, or soft ambient sounds...basically for taking care of quiet sounds at the opposite end of the spectrum from the battery box (which covers louder/bass-heavy sounds). A battery box WITH preamp can cost a lot of dough (if Sound Professionals are any indiciation!), and you should think about what you'd end up recording so you can decide if you really need one. Quote Link to comment Share on other sites More sharing options...
