Guest Anonymous Posted March 3, 2003 Report Share Posted March 3, 2003 Hello, When I record analog material with my MZ-N707 minidisc recorder, I sometimes get strange noises (I assume it`s some kind of distorsion) on high volume signals. I do what the manual says, i.e. I never record at volume higher that the 8th (one before the last) bar on the display. I record from a Linn Classik system or a Linn Genki/Kolektor combo. Someone having the same problem? Should I get a deck (JB-780 or JB-980) instead of the N707? Thanks Quote Link to comment Share on other sites More sharing options...
Mystyler Posted March 3, 2003 Report Share Posted March 3, 2003 It could just be the analogue signal - cracks, pops, etc are to be expected from analogue, unless you have spent $$$ on a proper setup. But do turn down the source volume a little - sometimes the signal distorts before the last bar. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 3, 2003 Report Share Posted March 3, 2003 Thanks for the reply, Mystyler. As my audio equipment is from Linn (Genki/Pekin/Kolektor/LK85 and Classik), I think I have spent enough$$$$$$$ for now... I mainly use my MZ707 to record radio concert (classic and opera) - maybe I will buy a digital tuner and use digital connections instead of analog. I tried to record digitally from my CD and - miracle! - no distorsion at all! Quote Link to comment Share on other sites More sharing options...
