SI: Sony Europe Introduces NAS-Z200iR Wireless Audio System With USB, iPod Compatibility
sony_041657_0609
In today’s digital environment, music sources are multiple: MP3 players, PCs, CDs, phones, radio, etc. To be able to easily access, connect and share is key for a seamless music listening experience. The NAS-Z200iR is DLNA Certified with Wi-Fi. So you can access the music library that’s on your PC and play your tracks back on the Z200iR all from your sofa or bed. Listening to Internet radio is also easy and fun directly using your home network and making radio station selection from Z200iR’s remote control, probably the most beautiful remote I’ve ever seen. Whether it’s choosing radio stations or songs from your PC or iPod, the remote control’s large 3.5-inch LCD display and friendly user interface allow you to sit back and relax for an uninterrupted music listening experience. Selecting by artist, album or song in your iPod is also easily done from the remote control without having to get up for your player to find what you’re looking for. The battery is rechargeable, and the color display is lit only when in use.
Home_HiRes
With Sony’s audio system, the flexibility is readily there to playback from different sources thanks to the integrated CD player, USB connectivity for a Walkman or any other MP3 player and an audio-in port. The CD player, which will play both audio CD and CD-R/RW discs with MP3 tracks, is discreetly integrated into Z200iR’s sleek design. If you like to listen to the radio in the morning, there’s AM/FM radio as well. All the choices are there.
092450_3_HFX-118_Z200iR_2
Skilfully hidden under NAS-Z200iR’s minimalist style is not only its multi-functionality but also its power to deliver sound. For the system, two independent speaker enclosures are incorporated (20W x 2), unlike some systems which use a common or single enclosure. For higher fidelity stereo sound, the enclosures are carefully constructed within the confines of space, to keep vibration between the speakers and the main unit to a minimum. For powerful and natural bass performance, strong magnets are required. In order to achieve this in such a compact unit, double neodymium magnets are utilised for the bass drivers.
The NAS-Z200iR will come to stores across Europe in mid September.
