RECORDING STREAMING RADIO
CORRY20
I have the Sony MZ505 net md and I want to record streaming audio.I use High Critera program to record Streaming audio but when I put it on my Net Md the sound is a little low.I want to have the sound recording louder I have the wave audio and the show I am recording turned up as loud as it can go how can I make it louder.I would really be happy for some help.Thank you
Have you tried turning up the volume on whichever program you're receiving the stream in? (Real Player, WM Player, etc.)
Some streams are inherently low in volume, and you can't fix them if you use NetMD. One solution is to record in real time (both digital and analog input is fine) and use the rec level control on the N505 to increase volume.
