mzr-91 test mode ....need a little help
Guest Anonymous
Guest Anonymous
I am having trouble getting out of test mode, i dont have a cd md so cannot use one to get out of it, I really need to know what the section numbers for the assy fro the mzr-91. I tried 0 24 but this does not appear can anyone tell me the one that applies for this md
thx for reading
Guest Anonymous
There are two ways of enetering test mode.
1 by pulling the unit apart
2 by pressing buttons in a given combination
If you entered test mode using method 1, then you need to pull your unit apart again and remove the test mode soldering point.
Otherwise, you used method 2, in which case, test mode is exited by draining all power from the unit.
As kindly provided by minidisc.org, here is a link to the MZ-R90/91 service manual. Read the section on test mode, it should answer all your questions.
http://www.minidisc.org/manuals/sony/servi...vice_manual.pdf
Nick S.
