ECM-MS907 with a SHARP MT80 Mini Disc
Mack Attack
I noticed someone post a similar quiery in an earlier post RE: A hissy Sony Mic using a Sharp Mini Disc recorder.
I have the same problem using a Sony ECM-MS907 mic with a Sharp MT80 mini disc.
The mic input on the Sharp is very hissy when the input level is turned up. This is really annoying because the mic cost £90. It sounded OK when I tested it in the shop. This was due to the background noise in the shop masking the hiss. It is really noticible when using in quiet conditions.
Can anyone suggest a way to PRE-AMP this mic cheaply? I've seen units on the internet that can do this but they cost anywhere between £90 - £200. I'm sure the components and circuitry would be pretty cheap.
Are there any techno heads out there who have built such a PRE-AMP unit after encountering similar volume problems?
Mack Attack
