Mic input
Guest Anonymous
Guest Anonymous
I have a N505 which as you may knows, doesn't have a mic input.
How can I record using a mic then?  Can I just use the line in?
thanks
yes but you will need something to bring the signal up to a line level input such as a pre-amp (50-150 you get what you pay for) or battery module (40-60$)
  • 3 weeks later...
