Guest Anonymous Posted April 16, 2003 Report Share Posted April 16, 2003 The subject says it all. I'm going to an Acoustic show on Friday, in a relatively small club (1000 people). I need to buy an MD recorder for it. What are some recommendations? Any tips I should know about where I should record? What kind of level should I set the recorder at? Anything else I'm not thinking of? Thanks! Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 17, 2003 Report Share Posted April 17, 2003 Get a sharp recorder if you can - but you probably can't, at least not by Friday. In that case, get a Sony recorder with a mic in - the 707 was popular, now the 710 is the replacement, but you might see either in a store. Learn to set the recording level. Unfortunately, with the Sony, you can't adjust while recording - you have to pause it. So make a good guess and adjust it if you need to. Get an appropriate mic. As a last minute thing, you might have to go to Radio Shack - it still should sound good. I'd recommend a stereo omnidirectional mic. Cardoid mics require you to point the mic at the speakers, which is probably too much of a pain. Put the mic(s) somewhere where they won't get brustled against. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 18, 2003 Report Share Posted April 18, 2003 I've got a sony mzn707, and if I had to change my md, I think I won't buy this again... I don't know for the 710, but the 707 hasn't any sensitivity switch... I recorded 2 shows with it , and the mini disc was overloading. and...the first of the two shows was...an acoutic set . :? so.... :!: :wink: ps: you can change the recording level while recording with the mzn707... Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 18, 2003 Report Share Posted April 18, 2003 oh I didn't see that...I think we are on friday now ANOTHER VICTIM ??? :evil: :cry: Quote Link to comment Share on other sites More sharing options...
