Guest Anonymous Posted April 17, 2003 Report Share Posted April 17, 2003 i have a MZ-N505, when i try to delete a track via the edit mode, i keep getting "SAVED" and so i cant delete the track, this also happens when i try to use T Mark on tracks?? is there a mode type in OPEN MG software that may cause this?? any advise would be great. Quote Link to comment Share on other sites More sharing options...
JeffS Posted April 17, 2003 Report Share Posted April 17, 2003 When it comes back as "SAVED" that means that you have the write protect tab set. Close that, and you can then make changes to your MD. HOWEVER!!! if you transfered via OpenMG, Sonic Stage, or Real One, you still won't be able to add/delete trackmarks, or delete tracks/disc. You will get an error that says Tr Prot (Track Protection). HOWEVER Yet Agin... If you transfered via Simple Burner, then you will have no problems. And yes, converting mp3s, to a cd image, or burning a disc, just to then reencode them to md, IS a pain. To simplify, there are a couple of programs you might want to consider... m3u2sb (converts, and mounts the image and launches simple burner, you do the rest) SimplerMD (converts, mounts, launches, transfers, and starts all over again depending on how many tracks you're moving) They each have a different set of software requirements, to do this, so the choice is up to you. Good luck -Jeff Quote Link to comment Share on other sites More sharing options...
