Guest Anonymous Posted April 20, 2003 Report Share Posted April 20, 2003 1. On the NZ707, if it's once had levels set manualy, will that level setting stay put between disc swaps, bat changes etc? 2. Is there a hack to make manual level recording the default? Also, I'm going to try to split my mic signal after the bat box and run into two MDs. Will that work? I'll know eventualy, but if someone is hot on this board and can answer in 10-15 minutes.... Thanks Quote Link to comment Share on other sites More sharing options...
radeon 21_ Posted April 20, 2003 Report Share Posted April 20, 2003 1) I have no idea what levels you are even talking about, be a bit more specific. Is it bass/treble level, recording level, what? 2) No Quote Link to comment Share on other sites More sharing options...
BJ Posted April 20, 2003 Report Share Posted April 20, 2003 I was under the impression that the machines that use the LR6 (AA) type battery completely power down after 15 minutes or so once the unit is turned off. You would lose your manual recording levels. However, given the battery life of the 707, why not just keep it on rec/pause, ready to go during the recording session? No band is going to hit the stage for more than 5 hours (unless you're recording Phish or someone). And if it comes to that, keep a few extra batteries and swap 'em during breaks. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 21, 2003 Report Share Posted April 21, 2003 Thanks, that's what I'm getting at... during a bat swap or between disc flips, will the man. recording level be remembered? Also, with a bat in the unit, and between recording sessions (days not minutes) will it hold those? I'm thinking that it does but was seeking authoritative confirmation. Later... Quote Link to comment Share on other sites More sharing options...
radeon 21_ Posted April 24, 2003 Report Share Posted April 24, 2003 Then I really don't know, on my r700, it saves the bass/treble settings and playback speed but seems to save personal disc settings inconsistently. Quote Link to comment Share on other sites More sharing options...
