Does the Sony MZ-R501 model have a LINE OUT?
Guest Anonymous
Guest Anonymous
Does the Sony MZ-R501 model have sepcifically a LINE OUT function or is it just a headphone-jack?
This is very important as i'm using it for the sole reason of recording my own music and uploading it onto a computer.
Now that i try it i found out there are a lot of common issues regarding this with MD's in general.
My problem is this; i can plug my headphone-out on the MDisc into mic-in on the computer BUT i only get a mono-streamed signal and not a stereo signal.
What i NEED to know, 100% from experts and not just basic shop-assistant guesswork, is whether the sony minidisc model MZ-R501 has the LINE IN function or not.
It is a fairly old model now, the manual dates as 2001, and it DOES NOT have a separate microphone input with it. (ie/ you can't plug an external mic into it)
So, has anyone else tried to plug this particular MD model's headphone out into a computer's (or cd-player/stereo's) LINE IN?
Other than that, does anyone know what programs i can use to test a computer's LINE IN socket? i have 2 computers, both with line in, and i'm not sure how i can send a signal through them or any programs that would play the LINE signal.
Guest Anonymous
Sorry, this one isn't about MD's as such, but sound card/program buffs could help me out, and its related anyway :roll:
What freely available programs can play signals from the LINE IN on sound cards?
(ie// can WinAmp play straight from LINE IN? and if the answer is: Yes, the next question is: How?)
Because i desparately need a faultless method for testing LINE IN on a couple of sound cards (and i've NEVER used it before).
You get only mono because you plugged it into the PC's mic jack! If you plug it into the line-in jack you'll get stereo, regardless is your unit has line out or not.
If you plug something into line in, you should hear sound from your speakers instantly - you don't need any special programs.
