Sony Portable MiniDisc MZ-R55 MO Focus Bias help...?!
Guest Anonymous
Guest Anonymous
Hello!
Anyone got anymore info on this little problem?I only vaguely understand
what's not happening!
In diagnostic/test mode when I run the Overall adjustment mode (Assy Mode) I get the failure MO mode NG code 39 F9.
If I then try the auto adj mode in the servo mode for code 39 MO focus bias it just seems to display the Cluster value / AT error rate / block error
rate (whatever they are!) and won't auto adjust.(ie not the display it shows for other parameters where it flashes the value until it is correctly
adjusted and then remains on steady).
If you try to play a minidisc it just spins up and cannot identify any
tracks.
Is this unit recoverable or should it be thrown?
I'm assuming that the laser / lens circuitry is to blame for this and not
one of the motors? (there is the sound of a motor trying to overrun
occasionally, but I was putting that down to the machine trying to find the
start of the disc! There's also a constant clicking every second or so
which I am assuming is the lens assy trying to focus from one end of it's
travel to the other and then dropping back to try again??).
Is there a component I could/should try to replace before I just throw it
away?
Cheers
Bob
