Guest Anonymous Posted May 26, 2003 Report Share Posted May 26, 2003 I use OpenMG V2.2 after recording i try to play the MD and it just says: BLANK. PLEASE HELP!!! am i doing something wrong?? Quote Link to comment Share on other sites More sharing options...
BJ Posted May 27, 2003 Report Share Posted May 27, 2003 Try recording from another source (like SimpleBurner or a direct connection to your stereo or a mic) and see if the recording takes. That way you can tell if it's the 505 itself or if it's just OpenMG being stupid again. You may have to reinstall the MD drivers on your computer or some nonsense. Also, check the basics: are you letting the MD write its table of contents before you eject he disc? Does the computer recognise the MD when you plug it in? Does Open MG record the whole track or just a couple seconds before it stops? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 28, 2003 Report Share Posted May 28, 2003 Simple Burner didnt work.... suicide inminent Quote Link to comment Share on other sites More sharing options...
