Kotarou Posted June 6, 2003 Report Share Posted June 6, 2003 I would like to know what is the correct voltage for the remote control (Like RM-MC11EL), My unit shows 2.40V between Pins 1 (GND) and 4 (RVDD), and with the AC-Adaptor it shows 2.75V. I tried to use R55 LCD remote and it just worked fine with AC-Adaptor, with the batery, there was no backlight and when pressing any key the LDC display blinked. I'm waiting for my Rm-MC11EL arrive. So 11EL will be compatible? Or my R700 have some problem? Can anyone Help me? * I was looking on my R700 Service Manual, At page 19 Adjustment of Vc PWM Duty (L) and Vc PWM Duty (H), The values are exactly the ones i got. Is there something related to this? Can i change values without toasting my unit? Quote Link to comment Share on other sites More sharing options...
Christopher Posted June 7, 2003 Report Share Posted June 7, 2003 Did you apply the '700 hack? Quote Link to comment Share on other sites More sharing options...
Kotarou Posted June 8, 2003 Author Report Share Posted June 8, 2003 I'v tried with the Hack and Without. These but the values between pin 1 and 4 , were obtained with the hack. Quote Link to comment Share on other sites More sharing options...
Kotarou Posted June 12, 2003 Author Report Share Posted June 12, 2003 FINALLY my Remote arrived... and it surprised me! it'worked perfectly without blinking like r55 remote. I'don't know why r55 remote blinked, but now i'm able to adjust BASS/TREBLE/PITCH and have LCD display with backlight on remote Quote Link to comment Share on other sites More sharing options...
