MZ-N1 USB Problem... help!
Guest Anonymous
Guest Anonymous
Hey,
I recently got my MZ-N1 but unfortunately have not been able to get it to download songs from my PC yet... here's the problem....
I installed OpenMG and the MZ-N1 drivers, and gave each a seperate reboot, then plugged put the MD into its cradle (i tried with and without the Ni-Cd battery), connected the cradle to the PC with the USB cable... windows xp recognizes it in the device manager... but the problem is that about 50-60 seconds afer it will DISCONNECT/SHUT OFF from windows xp no matter if im actually using the MD or not... note that i've timed this and the disconnection repetedly occured 50-60 after connection to PC.
What's going on??? Without a stable connection to my PC I can't do anything!!
I'm using windows xp home with 6 usb ports... ive read about the USB hub problem thingy... im not sure if its related to that.... in device manager this is what i have listed under USB:
SiS 7001 PCI to USB Open Host Controller
SiS PCI to USB Enhanced Host Controller
USB Root Hub
USB Root Hub
USB Root Hub
USB Root Hub
Please help... there must be some way to keep my MD steadily connected to my PC!!!!!! :cry:
Thanks so much,
Mark.
