roadhog Posted June 28, 2003 Report Share Posted June 28, 2003 Hi to everyone in this forum. This is my first post in this forum and I want to ask something. Since the radio of the sony g750 is in the remote control, can you buy a separate remote control? I mean - is this remote control in store in the shops? And IF I can buy just the remote control - will it be working on my minidisc? I have a Sony R501. Thanks in advance... Quote Link to comment Share on other sites More sharing options...
Cheese Posted June 29, 2003 Report Share Posted June 29, 2003 NO it wont work. 1. because your 501 has no remote control socket anyway 2. because only the G750 and G755 and the NF models supply enough power to the remote to use the radio, you would only get the standard functions, not even the display works. There are places to buy them, i just cant remeber where, try sony spares, but you'd need a new MD to use it anyway....G755 only £100 on amazon.co.uk a little while ago.. Quote Link to comment Share on other sites More sharing options...
Dark MD Posted October 8, 2003 Report Share Posted October 8, 2003 Would it be possible to connect an exteral power supply??? Have a N505 (US no remote) and got the RM MZ1T remote (A$10) (was in junk bin at store!) Currenly the Display only shows battry life and track. Quote Link to comment Share on other sites More sharing options...
