fatpotatohead Posted July 16, 2003 Report Share Posted July 16, 2003 Hello, i finally made my first live recording with my Sharp MD-MT180, Sound Prof minature binaurals and Sound Pro slimline battery box through the line-in input. The quality is very very good, i put the recording levels to max and i think the bass roll-off to 96KHZ, the only minor problem is that the bass drum is too crunchy. Anyways, my real problem is that on the last song, it stops and then plays a second then stops at one part many times for about 10 seconds of the song. I think it could be the minidisc or my recorder?, is there any way to clean the minidisc if it is that problem so that it plays smoothly instead of locking up every second? Cheers fatpotatohead Quote Link to comment Share on other sites More sharing options...
catchpole Posted July 24, 2003 Report Share Posted July 24, 2003 I had this problem with my Sony MDS-E10. A few recodings had big jumps and gaps in them. There was very little room at the desk so a sat the recorder on a weird angle on a pile of cables. Maybe it was caused by accumulative vibration. These units can deal with a little vibration (I guess) but maybe over 10 seconds or more, it was unable to keep up. Since then I've placed the recorder or a nice flat surface and all has been fine. I cant say for sure what the problem was, all I know is that it's gone away. christian@catchpole.net http://catchpole.net/ Quote Link to comment Share on other sites More sharing options...
MD4DNV Posted July 26, 2003 Report Share Posted July 26, 2003 I had a similar problem with my MZN707. Turns out it was vibration. I just got a foam pad to put it on and the problem was cured. Quote Link to comment Share on other sites More sharing options...
